Configures the automatic interface costs for 10 Mbps, 100 Mbps, and 1 Gbps interfaces, and optionally, the 2.5 Gbps, 5 Gbps, 10 Gbps, 25 Gbps, 40 Gbps, 50 Gbps, and 100 Gbps interfaces.
| cost | Specifies the interface cost for the indicated interfaces. |
The following command configures the automatic interface costs for 10 Mbps, 100 Mbps, and 1 Gbps interfaces:
configure ospf metric-table 10m 20 100m 10 1g 2
The 40 Gbps parameter was added in ExtremeXOS 12.6.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
